| Message |
Also, unless you suck a lot of air into the system, you probably don't really need to bleed the ABS very often. I've bled mine a few times after working on brakes and brakes lines, and even when I had a ton of air in the front lines, there was never any air at the ABS unit.
"The two seater is being joined in a few weeks by a larger two-plus-two model with a rear seat for munchkins." ~Jim Mateja, Chicago Tribune, in regards to the Z32.
Andrew Janeshek // jnshk@aol.com // 1992 NA 2+2 [Stage 2-ish]
